For my kenmore laundry center model #417.99570110 the washer will fill on rinse, will agitate, will pump out, but will not spin. Also, the washer will not fill on any wash cycle...PERIOD! Can anyone please advise on what may likely be the problem?
I've replaced the start capacitor, without success.
The motor for the agitator works, it's the high side I'm concerned about. I have the schematic and it appears that there is an overload switch somewhere. Does anyone know where it is and if it is resettable?
Could it be the timer? And if so, are there any special tricks to removing and replacing it?
Any assistance or guidance would be appreciated.
Rank:: Advanced Member
The Timer seems like the most likely problem. This is a Frigidaire model sold under the Kenmore brand name. Here is a link to the service manual. http://www.emaservicetips.com/pdfs/488_3.pdfIt will show you how to replace the Timer and check other parts.
Thank you! I'll print and take a look. Much appreciated.
