My Ice Maker is not working. Water WILL still dispense. The ice tray isn't filled and won't fill. The Sensor light on the right side is flashing. I have reseated the ice bucket. I have checked the filter. I have the ice maker that has an on and off switch. Any advice would be greatly appreciated. After looking on all the posts here it seems as thought I may need a new ice maker or sensor. Not sure how to tell which. Thanks again! Cindy
Groups: APP Team
Hi. First check if the fill tube is not frozen and if it is - replace it with kit Part number: 4389174
If it's not frozen test the optics and icemaker, using the attached instructions. Simon.
Simon, Thank you for your reply. Would my water line/lines be fronzen if I can still get water? I pulled the fridge out last night. Lines looked fine both behind and underneath. Also I don't see any attachments, can you tell me where to look for them? Cindy
Groups: APP Team
The water line I'm talking about is inside the freezer where the icemaker fill cup is.
Simon.
