MGibellino
#1 Posted : Thursday, December 6, 2012 5:36:30 PM(UTC)
MGibellino
Wired my dryer wrong and it tripped breaker and burnt out thermal limiter. Replaced thermal limiter, wired cord correctly and still no power to dryer. What else could be wrong?
#2 Posted : Friday, December 7, 2012 1:40:12 AM(UTC)
Parts for Frigidaire AEQ7000EG0 Dryer - AppliancePartsPros.com
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
I am not sure why the thermal limiter blew but even with it blown I think you should get some indication of power on the display. As far as I can see the limiter just kills power yo the motor and drum light but I am not 100% sure about this.
Could be you blew the control board.
File Attachment(s):
AEQ7000.pdf (383kb) downloaded 9 time(s).
