phillips
#1 Posted : Saturday, September 19, 2009 10:34:38 AM(UTC)
phillips
Only gets a trickle of hot water.
sidfink43
#2 Posted : Sunday, September 20, 2009 3:12:37 PM(UTC)
sidfink43
The inlet valves have mesh screens that act as a filter. Check the hot water inlet and clean it out.
If this does not fix it, you will probably need to replace the inlet valve assembly.
Here is the part
Part number: AP4248017
Good luck
