smodes
#1 Posted : Thursday, August 2, 2012 11:08:02 AM(UTC)
smodes
Surface burners work fine. Bake igniter does nothing, broil igniter glows
but does not light broil burner. What could be my problem?
Simon / APP Team
#2 Posted : Thursday, August 2, 2012 12:07:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely both ignitors are bad. Check the bake one for the continuity.
Check the broil for the current draw. If it's less then 2.5amp - replace it.
Both ignitors are the same Part number: WB2X9154
Here are the breakdown diagrams and Replacement parts for General Electric JGBP33CEH1CC Gas range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 6/5/2015 10:52:55 AM(UTC)
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle (Oven Repair (including Ranges and Cooktops))
by AKJim 11/23/2014 5:19:54 PM(UTC)
Oven does not work; everything else is fine (Oven Repair (including Ranges and Cooktops))
by 9hackler 9/21/2014 5:07:11 PM(UTC)
Upper oven does not work (Oven Repair (including Ranges and Cooktops))
by billhoch77@yahoo.com 6/24/2014 11:25:36 AM(UTC)
Whirlpool oven does not work but burners on top do. (Oven Repair (including Ranges and Cooktops))
by formula2fast 12/25/2012 7:13:16 AM(UTC)
electric oven does not work (Oven Repair (including Ranges and Cooktops))
by pawpawrick 10/8/2012 9:35:37 AM(UTC)
whirlpool oven does not work (Oven Repair (including Ranges and Cooktops))
by Alketa 6/9/2011 8:23:05 AM(UTC)
kenmore oven does not work cooktop works (Oven Repair (including Ranges and Cooktops))
by voles 3/9/2011 5:38:56 PM(UTC)
Oven does not work after cleaning (Oven Repair (including Ranges and Cooktops))
by mzarahemla 1/26/2011 5:32:35 PM(UTC)
Oven does not work/heat (Oven Repair (including Ranges and Cooktops))
by karenlu 1/4/2011 8:58:56 AM(UTC)
Oven does not work (Oven Repair (including Ranges and Cooktops))
by esauseda 10/18/2010 11:05:41 AM(UTC)
Oven does not work! Frigidaire/Electrolux (Oven Repair (including Ranges and Cooktops))
by justbarbie 10/3/2010 6:45:29 PM(UTC)
Oven Does Not work UUUGH (Oven Repair (including Ranges and Cooktops))
by Puwata 8/8/2010 10:01:45 AM(UTC)
Viking dual fuel range oven does not work (Oven Repair (including Ranges and Cooktops))
by Ren10 4/22/2010 9:31:38 AM(UTC)
Oven does not work. (Oven Repair (including Ranges and Cooktops))
by Frigidaredout 10/24/2009 2:56:12 PM(UTC)
