Have not used it in about 3 years but other fridge stopped cooling. Plugged it in and it runs and cools fine for about 4 hours then trips the gfci in the outlet. I removed the cover at the bottom and made sure it was clean. The compressor seems really warm to me.
Groups: APP Team
Hi.
Please check the model number, the one you posted doesn't come up.
Thank you.
Simon.
Sorry it's MSD2556AEB.... Also I think that the fan is not coming on so the compressor overheats and trips the gfci. Do you think that could be a cause?
Groups: APP Team
Hi.
Check if the condenser fan motor is running or not. Open the back cover and visually determine that.
Please, post the results.
Simon.
Ok I will check and let you know. Would that be the cause of the gfci tripping?
Groups: APP Team
Hi.
Possible. Also it could be the short in the defrost system. We need to take it step by step.
Thank you. Post the results.
Simon.
