Lori328
#1 Posted : Tuesday, July 31, 2012 3:49:25 AM(UTC)
Lori328
I have a Maytag French Door Refrigerator with Bottom Freezer Model MFI2568AES with an Ice/Water dispenser in the door. The refrigerator stopped dispensing water and ice. The front panel has power and the light is on. If I unplug the refrigerator and plug it back in water and ice will dispense once, then stop again. Any suggestions would be appreciated. Thank you.
#2 Posted : Tuesday, July 31, 2012 4:07:30 PM(UTC)
Sounds like the problem is a bad dispenser control board.
- The control board Part number: 67006294
Lori328
#3 Posted : Tuesday, July 31, 2012 5:54:05 PM(UTC)
Lori328
Thanks Gene.
#4 Posted : Wednesday, August 1, 2012 2:40:44 PM(UTC)
artsram
#5 Posted : Monday, March 11, 2013 7:30:13 PM(UTC)
artsram
Hello Gene, I have similar problem. I disconnected the Cavity motor and mullion connector from the LV board (J3). It has a blue/white, Blue/red, Red/BLK. The ice flap does not open and close once I disconnected the connector. Problem is that the water and ice doesn't work and the LV Board would flash on and off. Basically nuts. I when into the program mode and turned on the cavity motor from off and it dispenses water but then I try the ice and it wants to...but goes back to the ice flap open and closes. I went back into the Program setting and the cavity motor resets to off. I read that others have replaced the HV board. Others the LV board. Once I reconnect to J3 it starts to flash numbers on the display and ice flaps open and close. I also talked to maytag and they say that no recall on this model. I believe so but they deny. Any suggestions?
#6 Posted : Tuesday, March 12, 2013 10:32:08 AM(UTC)
What is the complete model number of the refrigerator?
artsram
#7 Posted : Tuesday, March 12, 2013 10:35:55 AM(UTC)
artsram
MFI2568AES
#8 Posted : Tuesday, March 12, 2013 10:42:02 AM(UTC)
Per the Maytag Service bulletin (attached to the post) the correction is to replace the HV control board.
- The HV control board kit Part number: 12920710
File Attachment(s):
artsram
#9 Posted : Tuesday, March 12, 2013 5:50:42 PM(UTC)
artsram
Hello Gene, I checked the HV board and found two CD282 Aluminum Electrolytic capacitor popped. I ordered the capacitors and will soldier them in and give it a try. If no go... then I will order a new board. I will keep you posted. Thanks again.
Artsram
