What is the easiest way to access the burner switches to test or replace them?
Right side Pilot light stays on when both switches for right side burners are turned off. Voltmeter test confirms that there is no voltage at the burner socket (burners removed) when the switches are off but the pilot light stays lit.
Remove all knobs and pull the range out of the wall to gain the access to the control panel end caps which are secured with the two screws. Both infinite switches have to be checked for continuity between the terminals P and L1. With the switch in Off position it suppose to be no continuity. - The infinite switch Part number: 700855K
