Groups ready for retrieval: Registered
My Kenmore dryer worked fine for many years but now the start switch welds the contacts together after about a months of use. Have replaced the switch twice and it works for a time and then the contacts fuse. Line voltage is fine. I have taken the switch apart and seperated the contacts and filed them smooth and about 3 weeks later they are fused again. What is going on? Switch is part # 33404233
Groups: APP Team
Hi.
Check the motor start amps ( the info is on the motor tag ). If it's more than normal - the motor is going bad.
Thank you.
Simon.
Thank you.
Simon. I was thinking the same thing.
Groups: APP Team
Hi.
Post the results.
Simon.
Post the results.
Simon. How difficult is it to replace the motor?
Groups: APP Team
Hi.
With the open end ranch on the blower wheel turn the motor shaft CW to take the blower off. You will need to take off two motor clips.
Thank you.
Simon.
