the LF burner indicator light will not stop. it is located below the knob that operater the burner. the use of the burner is still ok. i think the switch needs replacement. i believe i have identified the correct PN of the switch thru sears. how do i get to the switch under the control panel so i can replace it?
Groups: APP Team
Originally Posted by: Simon / APP Team thanks for the idea. do the 3 screws above the oven door and under the front part panel have to be removed first? also do the end caps have to be taken off before i try to lift the glass? thank you mountain
Groups: APP Team
Hi.
Take the glass off first, then you should be able to get to the switch.
Simon.
Successful replacement of LF Switch. Steps followed. TURN OFF POSWER AT THE BREAKERS OR UNPLUG 1- remove (slide)range forward out of location in countertop far enough (6-8 inches so the end caps are totally free of the countertop. 2-remove screws in side of R and L end caps of control panel. 3- remove three screws on underside and front of control pane. 4- carefully raise the front of the control panel enough to gain access to the switch. 5- remove the LF knob, nut and washer on the top of glass which holds the switch in place. 6- remove the crimping devices/wires one at a time from the old switch (there are 5 of them) and attach to new switch. 7 - reverse the steps. Thanks to all who sent in their suggestions. mountain
Groups: APP Team
