cflick
#1 Posted : Tuesday, June 19, 2012 7:13:54 AM(UTC)
cflick
Delongi DHE 90 dehumidifier [S/N 3 12 11 So1 P 045630]. The humidifier runs, fans and controls work, but it stopped producing water. It appears that the humidifier function (green light on panel indicating the unit is humidifying) is not operating.
Is this model worth repairing?
thanks
richappy2
#2 Posted : Tuesday, June 19, 2012 2:21:03 PM(UTC)
richappy2
Sounds like you have a bad humidistat or thermistor
richappy2
#3 Posted : Wednesday, June 20, 2012 5:32:17 PM(UTC)
richappy2
I am currently working on 2 dehumidifiers with the same problem and I have to say that both fans come on and compressors but yes no water, I cant believe they both would be low on freon but I would have to go with that because if the pressure switch or thermistor were bad the fan and compressor would not turn on.
