greyson1
#1 Posted : Monday, June 18, 2012 11:59:42 AM(UTC)
greyson1
In Door Dispenser dispenses water but not crushed or cube ice. I can open the door open while holding the door switch and I can see the auger turning and hear the motor running but no ice. I can switch between crushed and cube and see the gear reverse. Any ideas on what part I need to fix this with since the motor and reverse appear to work properly. Thanks, Greyson1
Simon / APP Team
#2 Posted : Monday, June 18, 2012 12:46:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the ice bin and check:
-if the ice door opens
-is there any blockage at the bottom of the ice bin
Rotate manually the auger (while the bin is out) and try to locate the problem.
Thank you.
Simon.
greyson1
#3 Posted : Monday, June 18, 2012 4:05:32 PM(UTC)
greyson1
:) :) I took out all of the ice and did the test you mentioned. I also ran HOT water over the bottom of the ice bin and it started to work. I will watch it to make sure it continues to work. Thanks for the quick answer. Regards, Greyson
Simon / APP Team
#4 Posted : Monday, June 18, 2012 4:55:28 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
