shalling
#1 Posted : Sunday, June 17, 2012 6:52:55 PM(UTC)
shalling
All burners on my electic stove do not heat. The red indicator light comes on but no heat. Have made sure all burners are connected right.
#2 Posted : Monday, June 18, 2012 2:24:46 AM(UTC)
Replacement parts for Frigidaire FDB751SCS0 Frigidaire/dishwasher | AppliancePartsPros.com
Does that include the stove top and oven elements?
If yes then odds are you have a power problem (no 240 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
electric range repair (Oven Repair (including Ranges and Cooktops))
by Phillip88 7/21/2011 4:44:12 AM(UTC)
Range Repair (Oven Repair (including Ranges and Cooktops))
by angels5491 5/31/2011 6:08:07 AM(UTC)
Gas Range Repair Help (Oven Repair (including Ranges and Cooktops))
by l_harding 3/25/2010 9:25:41 AM(UTC)
by wtravis 7/11/2009 11:00:03 AM(UTC)
Hotpoint Range Repair (Oven Repair (including Ranges and Cooktops))
by jbox 6/30/2009 11:59:24 AM(UTC)
by pcroe 6/12/2009 12:43:03 PM(UTC)
by sheri vliet 4/6/2009 7:22:45 AM(UTC)
by lamson471 8/2/2007 7:38:42 PM(UTC)
