Leaking line at filter/cartridge under freezer section. Not sure what white cartridge is, perhaps a filter, which I probably need to change as I am getting some sand from well. Could not identify part on drawings. If not a filter what is it and what is likely cause of leak? Did not want to pull apart as it would cause a big mess. Ice maker is working ok...Thanx for help
Is this filter build-in or in-line? Can you post a picture of it?
Hi Lowell, I received your reply through the Forum email. It will be better if you'll post it here, on the forum. Just click on the "Quick reply" button and type your text in the window. Then click on the "Post quick reply" button. It's easy to replace this in-line water filter. Before you'll do it, check wher it's leaking from: the filter itself or the water line tubing. If it's tubing and it's made of plastic, then just cut off a damaged piece and use the rest of it. - The in-line water filter Part number: 4392949
