The fridge stopped freezing and when I pulled it out I noticed the condenser fan wasn't turning.I tapped it with my screwdriver and it started and the compressor started clicking on and off and the stayed on. The next morning some ice had formed in the cup of water I put in but not solid. Everything had failed (I assume the fan didn't restart after the defrost cycle) I replaced the condenser fan as well as installing an RO41 (ic13) on the compressor. The compressor now runs and pulls 1.6A (the new fan is a massive .5A...overkill but it was all they had). The glass of water is barely cool to the touch. What am I missing that could be wrong? Thanks
