SPelton777
#1 Posted : Friday, May 18, 2012 2:48:48 PM(UTC)
SPelton777
Just got done replacing timer in the Magic Chef MCBR1020W & also have the parts you sent to replace the Defrost Thermometer (part 502413000036) & Defrost Heater (502415000078). The manufacturer has obviously changed the heater as it has several rows of coils vs. the single coil that fit under the fins. How exactly do I replace this without risking breaking the cooper tubing attached to the fins? Actually need some detailed instructions. Whirlpool was of no help.
And on the thermometer, is there a certain way these need to be positioned and/or attached after the heater is installed? :eek:
SPelton777
#2 Posted : Saturday, May 19, 2012 10:29:26 AM(UTC)
SPelton777
I've attached pictures to better explain my confusion .. or at least I think I've attached them. Thank you!
WPL ice maker and ice dispenser.pdf (1,479kb) downloaded 9 time(s).
16026736 - MAH9700.pdf (585kb) downloaded 23 time(s).
SPelton777 attached the following image(s):
