Dear Appliance Repair, I need an new control module display, part # 266746 or AP2802870, I think they are both the same. The question is does this control module display also have the circuit board connected to it? If you look at the module's photograph the circuit board connects to the ribbon wire located on the upper right side of the module. Is it all one unit? :confused:
