jgram
#1 Posted : Friday, September 4, 2009 4:56:48 AM(UTC)
jgram
So far your web site has helped me with my attempts to fix our Maytag MLE2000AYW stackable washer dryer but I have a few questions. The drum does go around and I pulled the heating assembly and it showed good or (0) for the fuse, low thermastat, High thermastat, and 11 resistance for the heating coil. I put it back together and it worked (So I thought). The wife used it this morning and it did not heat. I put the timer on the setting I tested it yesterday and it still worked (the more/Less dry area of the timer) but at the normal time digit area and perm press it does not heat. Could it be the timer? or should I be looking for somethinng else?
I checked the braker, checked the electric posts where the plug wires in and I checked for obstructions in the venting as well. All good.
Any help to narrow the search would be of a great help so that I do not order the wrong parts. You have saved me from ordering a heating assembly so far.
Greg Jenswold
jgram
#2 Posted : Friday, September 4, 2009 12:38:11 PM(UTC)
jgram
sorry wrong post
