John Shakib
#1 Posted : Tuesday, September 1, 2009 6:35:13 AM(UTC)
John Shakib
I have a Whrilpool (Modle # GHW9100LW1) front load washer that leaks. I have found the door seal is torn and I know where to order the replacement part. I want someone to tell me how to take the old one off and install the new one. I am trying to avoid taking parts off that I don't need to. Please help.
John Shakib
sidfink43
#2 Posted : Wednesday, September 2, 2009 8:29:20 AM(UTC)
sidfink43
There is a wire spring that holds it on. Take this off and the boot will peel off. The problem is getting the new it back on. Have a helper, and a lot of patience and a good supply of cuss words.
Here is the service manual that will give you some pictures and some tips.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
Whrilpool front load washer leaks (Washer Repair)
by John Shakib 9/1/2009 6:44:16 AM(UTC)
