andymb
#1 Posted : Saturday, August 22, 2009 2:50:03 AM(UTC)
andymb
I have a sharp R967 microwave oven,grill and convention.
The timer stops after 59 seconds no matter what time is set and you have to press start again.
I was told it was the damper motor that needed replaced.
I bought one and replaced it and the timer now works but this motor opens a plastic door and it not working correctly.
I think this is because the orientation of the motor is not correct.
My question is - Should this door venting the oven be closed when switched off and open when on.
If I know this then I can set the door to the correct position and adjust the motor to work correctly.
Look forward to a quick response.
Thanks,
Andy
microwave oven Fuse blew, replacement blew too after 1'2 second. (Microwave Repair)
by paulmars 5/26/2022 2:21:47 PM(UTC)
Panasonic 1250W microwave oven (Microwave Repair)
by Guest 11/7/2021 5:13:30 AM(UTC)
No Beeping - Emerson Microwave Oven (Microwave Repair)
by Wkolosi 1/18/2021 4:08:40 AM(UTC)
Whirlpool microwave ovens countertop (Microwave Repair)
by boxershubhammm 9/23/2019 10:06:07 PM(UTC)
LG Microwave Oven (Microwave Repair)
by KJ43026 1/10/2018 4:53:45 PM(UTC)
Our Microwave Oven stopped working (Microwave Repair)
by Artista 12/26/2016 8:32:57 AM(UTC)
Microwave oven LATCH (Microwave Repair)
by MAKODOG 4/18/2016 5:32:27 AM(UTC)
by blbweston 4/21/2014 11:13:01 AM(UTC)
How To Change The Bulb In Microwave Oven Combo (Oven Repair (including Ranges and Cooktops))
by Lax21 2/1/2014 10:21:18 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:57:58 AM(UTC)
by JOSEPH MONNEY 11/13/2013 10:47:08 AM(UTC)
Belarus johnny wen 6/20/2013 6:39:36 AM(UTC)
GE Profile microwave oven (Microwave Repair)
by alpinebucks 6/13/2013 12:47:08 PM(UTC)
Low heat from OTC Microwave Oven (Microwave Repair)
by Whirlpool OTC MicroWave 5/27/2013 2:26:18 PM(UTC)
GE Profile microwave oven - replacing the board latch (Microwave Repair)
by srduff1977 11/5/2012 9:46:52 AM(UTC)
