normdyer
#1 Posted : Friday, January 11, 2008 9:08:16 PM(UTC)
normdyer
When installing the plastic tubing to a replacement ice make water valve is there any sealant required or does the tubing just slip in?
abbie
#2 Posted : Saturday, January 12, 2008 7:15:02 AM(UTC)
abbie
There is usually a compression fitting that slips over the tubing.This fitting goes under the plastic nut. When the nut is tightened to the valve this fitting compresses to form a water tight connection.
normdyer
#3 Posted : Saturday, January 12, 2008 12:33:56 PM(UTC)
normdyer
there is no nut. the tubing just slips in.
tdreid
#4 Posted : Wednesday, January 20, 2010 3:18:44 PM(UTC)
tdreid
My Problem/Question:
I'm having the below mentioned issue with an Amana 22 (Model No. TLI22KL). My water inlet tube cracked...I've replaced the tubing but I am having a problem properly sealing the tubes connection to the water valve inlet. I don't seem to have a compression fitting that slips over the tubing (new tubing didn't come with one either). When I removed the defective tube there wasn't a compression fitting, just a spring in the tube.
Can you tell me if I need to purchase a compression fitting to seal the connection?
If so, do you know where I might be able to purchase it?
Or, should the tubing somehow seal itself in the plastic nut?
Abbie's answer:
Original Question:
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
ice maker valve installation (Refrigerator & Freezer Repair)
by bjustice 4/30/2009 4:47:26 AM(UTC)
ice maker valve opening with water dispenser (Refrigerator & Freezer Repair)
by sunbob 8/20/2008 8:30:01 AM(UTC)
