The bake element in the oven popped and broke. I then ordered the bake element and replaced it. Now everything works except the bake and oven elements. I need to know what part(s) to order. Frigidaire model # FEF366EMD... Thanks
THIS FORUM IS DEAD!!!!!!! |
Thanks your answers confirmed what I thought. Now how do I test the old control board before I fork over the $85. I'm a Novice so please make it easy for me.. Or should I jUst have my homeowners insurance have it repaired. Only problem with that is that they always send out the worst companies to do a job. Plus I can't take off work for the appointment. Last time I used them it took 2 months and 3 different companies to fix an A/C unit.
If its just a take out screws here then unplug this then screw the new one on then I would much rather do it myself and spend the extra $25. Any advice would be helpful.. Thanks
There is really not a good way to check it.
So you check everything else and if it is OK then have to assume it is the control board. |
