sarcza
#1 Posted : Tuesday, March 6, 2012 12:09:58 PM(UTC)
sarcza
The washer made a loud noise then stopped spinning. I've replaced the coupler and the clutch. I put it back together, seemed to spin ok so I loaded it and started a load. It filled, ran a wash cycle, and drained mostly then wouldn't spin anymore. The clothes are dripping wet. Any ideas/suggestions? I have also ordered a new lid switch, but the switch seems to function ok, just the bracket holding it to the lid broke.
Gary/APP Team
#2 Posted : Wednesday, March 7, 2012 10:40:05 AM(UTC)
mattt
Groups:
Hello. Since you have replaced the coupling , and the clutch, did you by chance take a look at the drive tubePart number: AP3094539
when you remove this you will be looking for the tube being scarred, the next thing is the drive block AP2905773'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP2905773" target="_blank">Part number: AP2905773
AP2905773" target="_blank"> AP2905773" border="0" alt="Part number: AP2905773" title="Part number: AP2905773">
AP2905773">
this will go over the drive tube, sometimes the grooved tabs for the drive tube become worn and when a large load is put in the unit will not spin like it should,I have sent you two attachments that explains this with a picture, thank you and good luck !
