Dryer doesn't get hot, I opened the front & the following is what I found. Looks like ignitor is working it glows & flame comes on for 5-10 second. Then flame goes out. Any suggestions ? Thanks, Mike
Originally Posted by: mikeo1899 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) dryer doesn't get hot, i opened the front & the following is what i found. looks like ignitor is working it glows & flame comes on for 5-10 second. then flame goes out. any suggestions ? thanks, mike mike unhook the vent hose from the back of the dryer and do the same test. feel and see if the air comes out hard where the vent is. if it does the same with the vent off, replace the coils on the gas valve. tom
Thanks, I will try it later when I get home
Originally Posted by: mikeo1899 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks, I will try it later when I get home I hope all went well. Tom ApplianceEducator.com
I changed both coils and it works fine now Thanks, Mike
Originally Posted by: mikeo1899 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I changed both coils and it works fine now Thanks, Mike Awesome!!!:cool: Tom ApplianceEducator.com
