Greg Smith
#1 Posted : Monday, August 3, 2009 6:12:19 AM(UTC)
Greg Smith
I need to replace the dual burner infinite switch. How do you access behind the control panel where the switch is located to swap out the switch? I see two screws at the front base of the control panel, but the heat shield visor blocks access to the screws.
Thanks,
Greg
David Matthew
#2 Posted : Wednesday, August 26, 2009 5:11:39 AM(UTC)
David Matthew
Greg---I'm looking for help with the same problem. Have you found an answer?
Limit Switch Replacement (Oven Repair (including Ranges and Cooktops))
by sandrair 11/17/2022 7:07:20 AM(UTC)
Avoid Siamesed Jenn-Air Cooktop Burners Upon Switch Replacement (Oven Repair (including Ranges and Cooktops))
by Tigertank84 2/26/2020 10:19:47 AM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
Switch Replacement Went Wrong (Oven Repair (including Ranges and Cooktops))
by gdavis8061 5/4/2015 5:32:41 PM(UTC)
Door switch replacement (Microwave Repair)
by pilotlite 10/1/2013 7:55:01 AM(UTC)
Infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by J_T 9/14/2013 2:43:04 PM(UTC)
Overload relay switch replacement (Refrigerator & Freezer Repair)
by dmckenna 7/25/2013 5:16:48 PM(UTC)
range hood fan switch replacement (Heating, Ventilation, and Air Conditioning (HVAC))
by Teacher3rd 5/8/2013 10:49:15 AM(UTC)
Thermador Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by JLondon 4/16/2013 2:17:18 PM(UTC)
Help with GE Spacemaker Door Switch Replacement (Microwave Repair)
by ssgmail 2/24/2013 9:54:34 AM(UTC)
Affinity door switch replacement (Washer Repair)
by nancybillj 2/6/2013 7:32:59 AM(UTC)
Range Hood Fan Switch Replacement (Heating, Ventilation, and Air Conditioning (HVAC))
by Chiral88 1/15/2013 2:15:53 PM(UTC)
cooktop switch replacement (Oven Repair (including Ranges and Cooktops))
by Al Lutz 5/28/2012 6:40:12 PM(UTC)
High limit switch replacement question (Dryer Repair)
by justj1161 5/23/2012 9:27:50 AM(UTC)
infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by inquisitive 5/18/2012 8:03:26 AM(UTC)
