mackb4
#1 Posted : Monday, August 3, 2009 1:53:52 AM(UTC)
mackb4
My Bryant 90+ more outside a/c unit contactor started sticking.Youn could bang the unit and it would quit,than about 4-5 hours later it would stick again.
So it finally started sticking all the time and I checked out the contactor,and sure enough it was toast.
So I simply replaced the contactor and nothing happed.You could plung the spring and the contactor would draw in but not keep the compressor or inside fan running.
The new contactor was not made exactly like the old one,and I apparently shorted out the new one,and the 24volt transformer.
So a freind who is a HVAC qualified tech. checked it out he told me how I had the contactor wired wrong,showed me how to wire it.
I then replaced the transformer and contactor,but the a/c will still not shut off.
Now when the t-stat setting is on auto and neutral,not air or heat,the a/c and fan does not run.But put the selector to a/c it runs the unit and fan all the time.The heat cycles as normal.
So what's wrong ? Do I have something wired wrong on the contactor ?
I've also put a good control board in that was loaned to me by my HVAC buddy and still the same results.
Oh and I changed the t-stat.
I need a wiring diagram or some real good advise.
I'm worried my electric bill will be skyhigh,or I'll ruin my unit.
Thanks for reading this long post folks.:confused: :confused: :confused:
mackb4
#2 Posted : Monday, August 3, 2009 2:50:04 PM(UTC)
mackb4
My problem is solved.
My HVAC buddy came over and ran a check on my old and new t-stat.BOTH ARE BAD :mad: !
He had a new one in his truck and BINGO,problem fixed :) .
If in doubt,call a professional :rolleyes: .
pelsaurrouborn
#3 Posted : Friday, February 1, 2013 7:39:31 AM(UTC)
pelsaurrouborn
Przed slubem nalezy wiele rzeczy przemyslec. W przypadku, kiedy bioracy slub sa dosc mlodzi i nie posiadaja swojego wlasnego mieszkania, powinni razem z rodzicami zastanowic sie nad tym, gdzie beda mieszkac. W sytuacji, kiedy juz posiadaja robote i dobrze Gru usato zyskuja, potrafia wydzierzawic dla siebie zamieszkiwanie. Jak zwykle w najdogodniejszej sytuacji sa ci, którzy posiadaja prywatny gmach. Oprócz decyzji dotyczacej miejsca zamieszkania, mlodozenców czeka jeszcze struktura slubu i wesela. W róznorakich czesciach naszego obrebu taka struktura wyglada niewiele inaczej. W sytuacji, kiedy ktos rozkazuje rozleglym budynkiem, moze zdecydowac sie na wyrzadzenie wesela w swoim prywatnym gmachu. Mozna tez zamówic wesele w wynajetej odbudowie, jest wtedy ciut drozej anizeli we osobistym gmachu, jednak pozbywamy sie wielu polaczonych z tym klopotów. Nawet Excavatrices konstytuujac wesele we osobistym mieszkaniu, bedziemy musiec zatrudnic kucharzy a takze obsluge kelnerska, bo co odmiennego przygotowywac posilki dla kilku spoleczenstwa - mieszkanców, a co odrebnego przygotowywac podarowania dla dziesiatek osobowosci, dla wszelakiej ludzi po kilka podarowan. Mozna ewidentnie przyzwac o usluge familiarnych, jednakze w tym wypadku ci, którzy beda wspierac przy struktury wesela, potrafia poczuc sie poszkodowani, bo kazda jednostka wolalaby siedziec w tym czasie za stolem weselnym, niz udzielac sie w kuchni w czasie, gdy wyrazni sie bawia. Jest takze mnóstwo pozostalych kwestii do ustalenia zwiazanych struktura slubu: fotograf na slub, ozdoba pojazdu Królestwa Mlodocianych, dekoracja klasie tanecznej, zespól muzykalny i sporo odmiennych. Najwygodniej jednak jest zaproponowac organizacje wszelkich kwestii specjalistycznej kompanii. Ostatnio powstalo w Polsce wiele tak zwanych "Domów Slubnych". Tego gatunku Domek Slubny najczesciej jest scaleniem restauracji z klasa taneczna i hotelem. Bardzo czesto kompanii tego typu nie tylko konstytuuja samo wesele, jednakze zajmuja sie tez pilotowaniem wszelkich kwestii dotyczacych slubu. Kompania tego gatunku pomoze zalatwic kazde formalnosci w USC, a takze w kosciele, zaopatrzy zespól muzyczny lub discjokeja, umówi termin u fotografa slubnego, zamówi kamerzyste na slub, dostarczy wóz wiozacy Nowozenców do slubu i ukatrupi mnóstwo odrebnych sytuacji zastygajacych sie ze slubem i weselem. Zlecenie organizacji slubu i wesela fachowej escort london filii umozliwi zarówno Nowozencom, jak i rodzinie Panstwa Mlodocianych skupic sie na samym slubie i pokojowo cieszyc sie tym istotnym dniem. Jedna z najznaczniejszych pamiatek z tego zdarzenia sa fotki ze slubu, tak dlatego na zacnym fotografie weselnym nie ma co odkladac, tym wybitniej, ze wydatek fotek slubnych jest nieszeroki, upodabniajac do sumie wydatków wesela.
