b_brown7
#1 Posted : Thursday, March 1, 2012 10:17:02 AM(UTC)
b_brown7
The front door display keeps going to an error message "Er IF" and does not allow options to be chosen (switching fom cube ice, crushed ice, or water; fridge / freezer tmp). Unplugging the fridge resets the display but the error returns after a couple of hours. Also it appears the in-door ice maker is not making ice and is leaking water.
Jerry / APP Team
#2 Posted : Thursday, March 8, 2012 12:26:20 PM(UTC)
mattt
Groups:
Hello. The "ER IF" code is an error code for the ice maker fan [AP4440210]. Before any parts are replaced, I recommend to remove the fan cover and verify no frost build-up is interfering with the fan operation. If there is frost present, clear any frost with a hair dryer and reassemble. Turn on the ice maker and see if the fan blows air into the ice room. If not, the fan has failed.
hollymolly
#3 Posted : Sunday, December 2, 2012 10:38:40 PM(UTC)
hollymolly
The over phone lg helper told me the fan has an ice built up
The temperature indicator screen is no longer viewable b/c of err message
The lg refrigerator default is set are at 37
Fridge at 0 degree
error message over the phone trouble shoot is follow:
I turned off the unit for 4 hrs
And turned it back on. The err 1f message was gone for 30 min and turned back on. It was very sad moment.
Now it is time to have a technician out.
They usu charge $100 for diagnostic
I recommend buying extended warranty on any LG appliances.
Lg technician will b here soon.
He said the fan Motor and ice maker will be replaced.
I will post more info as I know more in three days.
