Mike A.
#1 Posted : Sunday, February 19, 2012 9:32:27 PM(UTC)
Mike A.
Dishwasher will not start. Control panel has power. Can run diagnostic test all lights illum on control panel. Shut door cycles between normal and rinse cycle a few times then rinse cycle for a couple of more minutes. No lights stay on after this cycle. I do not have the sheet from the kick panel so I don't know if this is a correct test. So once again, I can select any cycle, but when pressing the start button nothing happens.
Any help would be greatly appreciated.
Thank you
ApplianceJunk
#2 Posted : Monday, February 20, 2012 4:18:24 AM(UTC)
ApplianceJunk
Check to make sure the water float inside is not stuck up and keeping the dishwasher from filling with water.
Mike A.
#3 Posted : Monday, February 20, 2012 4:26:36 PM(UTC)
Mike A.
Thank you for the response.
Checked the float and it is not stuck. Float switch has continuity.
Checked voltage to water inlet valve. The only way I could get power to it was to do the diagnostic test. When it switched to normal I got 104 volts to the water inlet solenoid. If the water inlet valve does not work would that prevent the washer from turning on?
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
