napclan6
#1 Posted : Saturday, February 11, 2012 12:33:13 PM(UTC)
napclan6
We have a Frigidaire Affinity dryer that we bought less than a year ago. During some remodelling, I accidentally drilled through the 220V line that supplies the dryer outlet (I know, pretty stupid!) and had to splice the wires back together. Now, when we tried to use the dryer, it ran for a minute or 2 and we got an error code E61. Any ideas?
#2 Posted : Sunday, February 12, 2012 1:52:46 AM(UTC)
Replacement parts for FAQE7072LW models | AppliancePartsPros.com
Here is a service manual
http://appliancejunk.com...wnloads;sa=view;down=259
And finally the tech sheet
http://manuals.frigidaire.com/p...df/Webster/137309600.pdf
Looks like E61 is a heat relay related.
I am not sure exactly what they are monitoring to generate this error.
If it is the temperature change then I would start by checking the power to the unit with a meter. If the 240 volts is missing then this error would pop up.
napclan6
#3 Posted : Sunday, February 12, 2012 2:32:54 AM(UTC)
napclan6
I actually figured out the answer shortly after posting my question. We have an older home, and the dryer is wired through an older fuse box using 2 35-amp buss fuses. 1 of the fuses was good, supplying enough power to the dryer to light the display and actually run it for a few minutes, but the 2nd fuse was blown. I replaced the bad fuse and the dryer is now running fine.
#4 Posted : Sunday, February 12, 2012 3:29:52 AM(UTC)
Glad to hear you found it.
You said you had to splice the wire.
Did you also add a electrical junction box at the splice.
If not then the splice does not meet electrical code.
The line is high current and it is not uncommon for connections to fail over time. Doing the splice in a metal junction box diminishes the possibility of a fire if it fails.
napclan6
#5 Posted : Sunday, February 12, 2012 5:23:49 PM(UTC)
napclan6
Thanks, I appreciate the follow-up to make sure I did the splice correctly. Yes, I spliced the line in a metal junction box with a cover plate. I actually found a couple other junction boxes in the basement that don't have plates on them. They will be getting plates very soon! Anyway, thanks for the help!
