How to remove hard plastic cover holding three pins on the dryer timer. These are located on right. I can't seem to pull the pins off old timer.
Originally Posted by: Bharat How to remove hard plastic cover holding three pins on the dryer timer. These are located on right. I can't seem to pull the pins off old timer. done. Now, the new timer does not advance. Dryer keeps running
Need more info.
What was the original problem with the dryer? Do you have heat? Does it not advance in both auto and timed dry mode? Have you done any troubleshooting on this latest problem? |
THIS FORUM IS DEAD!!!!!!! |
It is working well. I just did no wait enough to notice the movement of timer know on front. It does move. Thanks for your help. Do-it-yourself saved a lot of money for me. Originally Posted by: denman Need more info.
