stevebarlow
#1 Posted : Saturday, July 11, 2009 8:11:35 AM(UTC)
stevebarlow
How do you test the oven thermostat? How do you open the stove cooktop to gain access to the burner and oven T'stat area?
I purchased the oven used. When I installed it, connected the nat gas line and then plugged it in, the oven ignitor comes on - on it's own and the oven burner ignites and stays on all the time. The oven thermostat knob/dail is free to rotate 360 degrees in either direction, so in effect the knob doesn't control anything.:confused:
Dan O.
#2 Posted : Saturday, July 11, 2009 1:24:45 PM(UTC)
Dan O.
That depends on the particular thermostat design and what you're 'testing' it for. The contacts of a simple 2-wire thermostat like used on your model can be tested for continuity to see if they're opening or not.
LINK > How do I test for continuity?
As long as the knob is not just rotating freely on the thermostat shaft, that would be a pretty good sign it was defective and likely needs to be replaced.
LINK > Kenmore 362.75291790 Oven Thermostat
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
