Rank:: Member
I've reset the circuit breaker to try and reset the control panel as well. The unit has 30 amp power, but the elements suddenly stopped heating. The oven is less than two years old and only lightly used. During the last successful use, there was an "electrical" burning smell, but no food spills were present inside the oven. We thought that was odd - now it won't heat at all.
What's your best guess as to the problem? Internal fuse? Temperature Sensor ASM? Something else?
Your advice is most appreciated!!:o
-Tom
