tinab
#1 Posted : Sunday, January 8, 2012 3:56:39 AM(UTC)
tinab
after a storm my control panel on jenn air not buttons worked, could not use oven only on display power loss had electricity to it. called you phone attandent said must be 85f07p233-60 got it next day put it in and it is still the same says power loss not buttons work. can you help what can i do!
kayakcrzy
#2 Posted : Sunday, January 8, 2012 5:04:47 AM(UTC)
kayakcrzy
Looking at your picture of the oven, if you replace the control board, then if there is a touch pad, that would most likely be your issue. I can't tell by the picture if your oven has a touch pad. But, if you had to hooh up a ribbon from the control panel to the board you put in, then you do. If you did not, there is a high limit switch on the oven, most likely in the back, that could be the problem. If you, don't have a touch pad, then you can kill the power to the oven, and pull the wires off of the thermostat, and there will be 2, and put them together, and put some tape around it, so the terminals don't hit metal, and then, turn on the power, and see if it works. If you have an ohm meter, you can pull 1 wire off of the thermostat, and see if you get continuity. The part # for the high limit thermostat is 74010818. Hope this helps. Tom ApplianceEducator.com
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
GE Front Control Panel Not Working (Refrigerator & Freezer Repair)
by Wingernet 2/17/2016 5:41:43 PM(UTC)
oven control panel not working (Oven Repair (including Ranges and Cooktops))
by nocookintoday 1/26/2016 8:04:15 PM(UTC)
PLES389ECE Oven control panel not working (Oven Repair (including Ranges and Cooktops))
Belarus tfmc369 10/26/2014 8:34:27 AM(UTC)
Control panel not working (Oven Repair (including Ranges and Cooktops))
by Dsteed1031 4/23/2013 6:53:31 PM(UTC)
New oven control panel not working (Oven Repair (including Ranges and Cooktops))
by MarshalW 2/13/2013 9:05:14 AM(UTC)
oven/clock control panel not working (Oven Repair (including Ranges and Cooktops))
by lasportsman 10/17/2012 3:43:15 AM(UTC)
Frigidaire Control Panel Not working; Range top works (Oven Repair (including Ranges and Cooktops))
by MThack 10/2/2012 11:21:36 AM(UTC)
Control Panel not Working (Dishwasher Repair)
by td1970 7/27/2012 10:42:06 AM(UTC)
Control Panel not working (Oven Repair (including Ranges and Cooktops))
by tmjenkins11 6/13/2012 7:46:08 AM(UTC)
Control Panel not working following self clean (Oven Repair (including Ranges and Cooktops))
by krozon 12/28/2011 4:36:35 PM(UTC)
Kenmore oven control panel not working -no "F" code (Oven Repair (including Ranges and Cooktops))
by DisneyMommy 10/19/2011 8:22:19 AM(UTC)
GE oven and control panel not working (Oven Repair (including Ranges and Cooktops))
by yardlet 2/15/2011 1:28:17 PM(UTC)
Dishwasher control panel not working (Dishwasher Repair)
by kredle 2/3/2011 7:06:52 PM(UTC)
