Hello, I am trying to replace aburner on my Frigidaire ( Model FCS388WECE
) dual fuel oven/range and am stuck at the point where I remove the glass top. Given that I cannot see any screws holding it on I assume that it has clips that push into the base to hold it in place, however, because it is glass I am hesitant to just apply force unless I am confident that that is what I should be doing. Does anyone have instructions for removing this panel? Thanks and regards, -Ken
