aec393
#1 Posted : Thursday, December 15, 2011 11:46:50 AM(UTC)
aec393
The bake element in my oven burned out and I have replaced it. The broil and bake elements are no longer heating however. Everything else (cook top, clock, oven light etc) are all functioning. I have ordered a new clock/timer and will see if that fixes the problem. (I have nothing to measure current...) I have no idea HOW to replace the clock/timer, however. Any precautions and instructions are greatly appreciated.
Joe / APP Team
#2 Posted : Thursday, December 15, 2011 12:59:52 PM(UTC)
Joe / APP Team
AEC,
Make sure you turn the power off to the range, or unplug the power cord and slide the range out enough to get behind it. Reove the rear control panel cover plate to access the clock/control. Remove the four mounting screws, and slide the assembly out of the control panel area, it'll be easier to work with the wiring after the control is out.
Good Luck,
