truleygood
#1 Posted : Thursday, December 27, 2007 1:41:45 AM(UTC)
truleygood
Our freezer has a vent hole in the back top right side of the freezer. This vent hole blows warm air when its not working. If I unplug the freezer for 10 seconds and plug it back in, it will work for another 5-8 hours, blowing cold air. I have cleaned off most of the dust build up on the coils. The frigde works fine.I have electronic background and I'm confident I can repair this problem (with a little help):)
#2 Posted : Thursday, December 27, 2007 2:41:24 AM(UTC)
You may have a compressor shutting down, also plug that hole up in the freezer wall. Next time it fails check the compressor, if power to it and no run, you have a failing compressor, please check and post.
truleygood
#3 Posted : Thursday, December 27, 2007 8:34:04 PM(UTC)
truleygood
I don't understand why I should plug the vent hole, can you explain?
Thanks, Todd
#4 Posted : Friday, December 28, 2007 1:19:13 AM(UTC)
Never saw a freezer with a vent hole unless it's for the ice maker line and they are plugged without an ice maker.
