The tub won't spin. The machine will cycle manually and the motor works fine. The drive coupling from the motor has been worn out, torn out and the remainder of it was lying on the floor under the washer. I need a new drive coupling which I will order, but I also need to know the procedure for changing it out. Please help. Thank you. Lou Agathos
Rank:: Member
