ktmarvin
#1 Posted : Thursday, December 8, 2011 6:13:12 AM(UTC)
ktmarvin
The water was not pumping out of the washer. So I replaced the water pump. It still will not pump out. The motor shaft turns freely. What else could be wrong?
ApplianceJunk
#2 Posted : Thursday, December 8, 2011 7:24:18 AM(UTC)
ApplianceJunk
Does the motor run during the drain cycle?
If not I would check the lid switch.
If the motor does run it is turning the pump so there maybe a restriction in the drain line, tub or the hose that is between the tub and pump.
