After replacing a door spring I replaced the gas hose, now the oven & broiler will not light, seems like gas is not getting to this section however the 4 burners on top all light with the auto spark. I tried to manually light the broiler but no gas, Is there a start up procedure I didn't do for the oven or is it a coincidence that the ignitor stopped today?
There is an "on-off" switch for the oven gas line on the gas pressure regulator - on the right side on the following picture. Very likely it is in the off position. Gene.
