2 Pages12>
Wayne Addison
#1 Posted : Saturday, December 3, 2011 6:30:38 AM(UTC)
Wayne Addison
The dishwasher is not drying the dishes. According to the repairman this model does not come with a heated drying cycle, only an energy saving dry cycle. He said that he could install a heat dry unit along with a control panel that would provide that option for around $500.
After speaking with a tech at AppliancePartsPro, I don't think he was giving us the correct info.
What do I need in order to have a heat dry cycle that would dry the dishes?
Thank you
Wayne
ApplianceJunk
#2 Posted : Saturday, December 3, 2011 6:38:53 AM(UTC)
ApplianceJunk
Did it use to dry the dishes?
If (and it's a big if) what the technicians said was correct I would think that the control board and control panel would need to be replace from a model that had the dry cycle.
ApplianceJunk
#3 Posted : Saturday, December 3, 2011 6:39:58 AM(UTC)
ApplianceJunk
What option do your buttons give you on the front of your dishwasher now?
Wayne Addison
#4 Posted : Saturday, December 3, 2011 11:28:50 AM(UTC)
Wayne Addison
The control panel read:
Baked on cookware
Normal
Light/china
Quick clean up
rinse only
high temp scrub
sani rinse
energy save dry
4 hour delay
hope this helps
Wayne
ApplianceJunk
#5 Posted : Saturday, December 3, 2011 11:36:02 AM(UTC)
ApplianceJunk
I would think with 'energy save dry' selected the dishes would drip dry and without it selected it would use the heater to dry them.
For the fun of you you should ask the technician that looked at it and see what he says about the 'energy save dry' option. :)
Wayne Addison
#6 Posted : Monday, December 5, 2011 10:46:30 AM(UTC)
Wayne Addison
I did ask the tech about the Energy Saving Dry and he replied basically the same as you did, ie; drip dry.
Do you think I need to replace the heating element and add a board with that option?
Thank you,
Wayne
ApplianceJunk
#7 Posted : Monday, December 5, 2011 10:59:16 AM(UTC)
ApplianceJunk
Yes, drip dry if it's selected and if it's not selected it should use the heater to dry them.
Your heating element could be bad, but from my experience I doubt it.
To check the heating element I would simple disconnect the power to the dishwasher, remove the wires from the heating element and check it with my ohm meter.
I believe the control board that is in your dishwasher now already has the option you are looking for, it's just not working.
ApplianceJunk
#8 Posted : Monday, December 5, 2011 11:04:50 AM(UTC)
ApplianceJunk
Here is a copy of the tech sheet for your model dishwasher.
It includes a troubleshooting guide that may help you better diagnose the problem.
File Attachment(s):
Tech Sheet - 8537797.pdf (982kb) downloaded 12 time(s).
Wayne Addison
#9 Posted : Monday, December 5, 2011 11:48:17 AM(UTC)
Wayne Addison
My main question is:
Does this model Kitchenaid come with a dry cycle in it's normal operation?
Thank you for your assistance.
ApplianceJunk
#10 Posted : Monday, December 5, 2011 12:13:52 PM(UTC)
ApplianceJunk
Yes it does.
2 Pages12>
