How in the heck do you remove the timer from the control panel?:eek:
I assume you have opened the console by removing the two screws at the outer end of it and flipping it up. Your timer knob should come off by pushing it in and turning counterclockwise. This will expose the screws that hold it on.
Good luck, let us know if this does not do it.
I've got the front panel off the washer and the knob off the front and I still can't figure out how to take the timing unit off to replace it. I know it's gotta be something totally obvious I'm missing - please help.
Without a brand and model number we have no idea.
Post your info and let's see what you got.
It's a Maytag Dependable Care heavy duty washer model #LAT8704AAE
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: tuggernuts I've got the front panel off the washer and the knob off the front and I still can't figure out how to take the timing unit off to replace it. I know it's gotta be something totally obvious I'm missing - please help. The center part of the timer knob is a "plug" just take the tip of a small screwdriver and pop it straight out. Underneath is a clip. Slide it off the shaft. The knob is spring loaded, don't loose the spring. Pull the pointer straight up and off. Underneath are some screws. See this diagram. Control panel replacement parts for MAYTAG LAT8704AAE Washer - Top Loading | AppliancePartsPros.com
