beast
#1 Posted : Thursday, June 4, 2009 11:21:16 AM(UTC)
beast
Cannot locate my user manual. Have a whirlpool gold series model GERC4120P oven circa 2005. What method to remove the door. Is my model the one that I need to install pins in the door hindge first before I lft up, I recall someone said that but not sure . Or do I use a different proceedure to remove the oven door . i want to clean the drip on the inside glass..
thanks allot
beast
#2 Posted : Thursday, June 4, 2009 1:49:10 PM(UTC)
beast
I called my uncle who had done some appliance servicing. I needed to open the oven door part way and insert a pin into holes on each oven door hindge. Then I had to use a small putty knife and remove a clip on the oven side just where the door hindge goes into the oven. I lifted up and straight back and the oven door became detached . Was a simple matter of unscrewing the three silver screws at the bottom and the trim pieces were now free. The glass door front (bisque in colour) was removed and now access was clear to the oven glass inner and outter windows . I cleaned the outter glass with a moist cloth and reassembled the oven door. Re-installed then door back into the oven , removed each pin from the hindge. Lastly installed the clips back into the opening just awhere the door hindge goes in . :) :) :)
oven door removal and replacement (Oven Repair (including Ranges and Cooktops))
by gmzal 7/8/2014 3:47:40 PM(UTC)
Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by Rayles 5/28/2014 2:06:30 PM(UTC)
Oven Door Removal/Hinge Repair (Oven Repair (including Ranges and Cooktops))
by Ken1000 5/23/2013 8:59:58 AM(UTC)
Oven door removal (Oven Repair (including Ranges and Cooktops))
by jyork1961 3/5/2013 10:57:27 AM(UTC)
by DRMay 1/4/2013 10:00:09 AM(UTC)
Maytag mgr5775qdq oven door removal (Oven Repair (including Ranges and Cooktops))
by ocirus73 11/30/2012 7:45:36 AM(UTC)
Whirlpool oven door removal (Oven Repair (including Ranges and Cooktops))
by ts756 8/17/2012 12:55:14 PM(UTC)
by mohinder 2/23/2012 12:45:55 PM(UTC)
by stevesr49 2/15/2012 7:59:04 AM(UTC)
Kitchen Aid oven door removal - going crazy (Oven Repair (including Ranges and Cooktops))
by sun4jessi 10/19/2011 3:08:54 PM(UTC)
Oven Door removal (Oven Repair (including Ranges and Cooktops))
by martybp 10/3/2011 7:30:23 AM(UTC)
Kitchen Aid oven door removal (Oven Repair (including Ranges and Cooktops))
by Grandmm 1/16/2011 11:55:55 AM(UTC)
by Dannyl 11/21/2010 7:22:41 AM(UTC)
Jenn Aire Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by JimmyW 2/4/2010 11:12:39 AM(UTC)
Kitchenaid Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by jrepac 8/3/2009 7:36:03 AM(UTC)
