cwbyfam
#1 Posted : Tuesday, May 26, 2009 3:49:30 PM(UTC)
cwbyfam
Hi, my dishwasher completes its cycle and all indicators on display panel turn off but the heating element stays on. Once the door is opened the element will turn off. Any troubleshooting tips would be appreciated.
lori
#2 Posted : Wednesday, May 27, 2009 3:04:27 AM(UTC)
Replacement parts for MAYTAG PDBL390AWB | AppliancePartsPros.com
Here is the tech sheet and a service manual
http://www.servicematters.com/m...ibrary/docs/16026393.pdf
http://www.servicematters.com/m...ibrary/docs/16021814.pdf
Since the only way to shut the heater off is manually by removing power from it (opening the door). It sounds like the control board is toast. If the board uses a relay to control the heater, it's contacts may be welded together.
Could try the diagnostics to see if it will shut off electronically.
