My Bottom Burner (bake) Burned Out. I Replaced It. Now I Don't Have Electricity To The Bottom Burner. The Top Burner (broil) Works. I Just Oreded The Limit Switch To The Bottom Burner (part #ap4101885) From Appliance Pros. If The Switch Isn't My Problem What Could It Be? Everything Works But The Bottom Burner.
If the new high limit switch would not solve the problem and there is nothing wrong with the wires then the control board is the culprit. In such case, if you need the correct part number for the control board, post the serial number of the oven.
The part number for the control board is AP4102875Gene.
