2 Pages12>
scri8e
#1 Posted : Wednesday, May 13, 2009 3:06:01 PM(UTC)
scri8e
I can't read a thing off the label. It's just a solid silver metal label.
It's a Magic Chef electric wall double oven.
It is 24 inches wide and 48 inches tall approx on the height.
http://s344.photobucket....scri8er/Picture010-1.jpg
http://i344.photobucket....4/scri8er/Picture009.jpg
It's installed in the wall of course. Is there some where else I can retrieve the model number on this oven?
I need to find replacement parts for this double oven. This is for a rental property.I am not at the rental property. So I don't have access to the oven.
The upper oven is not working. The lights are not turning on ... on the control panel/dashboard.
No heat in the upper oven comes on. Only the lower oven came on before we took it apart.
We do not have electricity at this property right now.
Upper heating element damaged spot on coil need to replace
http://i344.photobucket....scri8er/Picture013-1.jpg
http://i344.photobucket....4/scri8er/Picture016.jpg
This is a thermostat?
120-240 Vac BONK! Can't find this part
(has the chunk blown out of it)
http://i344.photobucket....4/scri8er/Picture011.jpg
Don't know if I need this?
This is a controller? Made by RobertShaw
EA69F-24-48
7404P039-60
OT-012-012-99
30A277 VAC
DL 500 F CL 940F
http://s344.photobucket....4/scri8er/Picture012.jpg
Here is the results for one of the parts. I guessed as best I could not having the model number.
http://************************...l.aspx?inventory=1653787
I don't know if this is needed or if it is the correct part for this oven that I don't have a model number for.
I'm all ears. Thank you for your time and help.
#2 Posted : Wednesday, May 13, 2009 7:23:17 PM(UTC)
Based on the information you posted looks like:
- The part number for the upper oven thermostat is AP4101800
UserPostedImage
- The part number for the selector switch is AP4101316
UserPostedImage
- The part number for the Broil element is AP4283351
UserPostedImage
- The part number for the Bake element is AP4283357
UserPostedImage
scri8e
#3 Posted : Wednesday, May 13, 2009 8:03:23 PM(UTC)
scri8e
Perfect! Many thanks Gene for your through answer to my post.
What is my model number do you know?
#4 Posted : Wednesday, May 13, 2009 8:42:54 PM(UTC)
I can not tell you exact model number of your oven, but I found a few very similar. One of them is 9844XPB.
DEBORA G
#5 Posted : Tuesday, December 4, 2012 11:47:28 PM(UTC)
DEBORA G
Hi Gene : This Is Debora And You Mentions The Selector Switch Would Be Bad On My Double Over For Magic Chef And I Got A New One And When I Hooked It Up The Fan Went Out And The Ovens Wont Turn On Without Fan , Could It Be Any Other Thing Besides The Fan? I Do Know That When Ovens Are On The Fan Stays On At All Time Until I Turn Oven Off! Been That Way For 15 Years! THE FAN WORKED THE MINUTE I TURNED IT ONE BUT SUDDENLY WENT OUT! THANKS AGAIN GENE
#6 Posted : Thursday, December 6, 2012 7:14:33 PM(UTC)
Hi Debora,
Remove the oven from the cabinet and check for 240 VAC to the oven at the junction box behind the oven. Check all wires from the oven terminal block into the oven.
DEBORA G
#7 Posted : Friday, December 28, 2012 8:22:12 PM(UTC)
DEBORA G
i changed every electric part in my oven and i found out the oven isnt getting 220 but the clock works so it only getting 110 what could this be , the breaker doesnt trip however ! please help me : debora g
DEBORA G
#8 Posted : Friday, December 28, 2012 8:33:34 PM(UTC)
DEBORA G
ha gene , could you please tell me what the wiring schematic is for the magic chef 9522? i took the back of the oven apart and repaired any wire that was a possible short! is it possible the thermo block is bad? i did a volt check and on one side it didnt read and on the other i got a reading and spark because i must have touched wrong wire while taking it out! thanks gene, debora g
#9 Posted : Friday, December 28, 2012 8:34:36 PM(UTC)
Hi Debora,
It can be a bad circuit breaker or a broken wires. It's impossible to visually diagnose circuit breaker. It has to checked for continuity. If you do not feel comfortable to work under power then it maybe better to call a certified electrician.
DEBORA G
#10 Posted : Friday, December 28, 2012 8:37:10 PM(UTC)
DEBORA G
i was wondering if i put one wire on wrong maybe ! the oven is hard wired , no plug so should i still check there ? how possible is it that the breaker on one side is bad even though it doesnt trip outwardly?
2 Pages12>
