johnwh
#1 Posted : Friday, May 1, 2009 3:57:38 PM(UTC)
johnwh
I have the Diagnostic sheet with the Automatic and Manual Function tests, Cycle map and Electrical schematic.
First I checked the water valve by removing the wires and applying an external 120V and the valve activated and water went into the machine.
Next I checked the Float switch and Door switch with a meter and they both activated properly.
Then I ran the manual function test and tried to activate the water valve. No water.
Finally I ran the Automatic function test. The water valve did not activate, but it showed a turbidity sensor failure. I didn't think that should prevent the machine from filling, so I ran the test again first manually putting in a gallon of water. I got the same result, Turbidity sensor failure.
My questions are:
Can the turbidity sensor cause the water valve to not operate?
(I hope not, because the turbidity sensor is not available)
Is there any more diagnosis I can do before replacing the circuit board?
Any Help is appreciated.
johnwh
#2 Posted : Monday, May 4, 2009 4:04:04 PM(UTC)
johnwh
I looked at EMEDD's post from 12/08 and I had the same broken wires from dispenser to water valve. Repaired and working fine (but I still get Turbidity Failure). Thanks for the Forum.
John
