brian450
#1 Posted : Tuesday, October 11, 2011 11:44:31 AM(UTC)
brian450
So I get a phone call today at work from my wife. The dishwasher was leaking water from the bottom of the door. When she found it, the wahser was still running (she thinks rinse cycle) and she opened the door to find the fill hole (left side of the washer) spraying water. The bottom of the washer was already full. She shut the door and pressed the cancel button. She opened the door again, and the fill hole was still spraying water. So the washer continued to fill even though it was turned off.
I came home and thought my wife had turned off all the appropriate water valves. We cleaned up the water and I turned on the water to the home and nearby sink (thinking the valve to the dishwasher was off...it felt closed). I took the face plate off and figured the water supply vavle must have failed. I disconnected the water line from the sink to the valve and water went everywhere! The valve I thought was closed was not....but the dishwasher water inlet valve had closed.
The little research I've done pointed me toward the Water Inlet Valve. Seems logical to me. I found a site that recommended a continuity test. I registered 70 ohms, not infinity like a bad valve should. I suppose the valve itself may have been stuck. Not sure. It didn't leak once the water was turned back on.
I've seen posts talking about Floats as well. Could there be a float in the washer tub that tells the washer to keep filling up? Is there any other sensor or device that could tell the washer to fill indefinitely?
Thanks for your help!
#2 Posted : Wednesday, October 12, 2011 6:33:57 AM(UTC)
Replacement parts for WHIRLPOOL DU980QPDQ5 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Yes I would replace the inlet/fill valve (Item 16 in Section 3).
If it was open with power off to the unit it is shot.
[COLOR="DarkRed"]
I've seen posts talking about Floats as well. Could there be a float in the washer tub that tells the washer to keep filling up? Is there any other sensor or device that could tell the washer to fill indefinitely?[/COLOR]
No to both the above as far as a sensor.
The control board could do this but the float/overfill switch should have killed power to the valve.
The float runs a switch that is supposed to kill power to the valve it the tub overfills. It is wired in series with the fill valve.
Of coarse if the vale sticks open mechanically then it cannot shut the water off.
