My machine seems to wash just fine, but when it goes through the spin cycle it's not spinning the clothes dry like it supposed to. Took off front cover of machine and watched spin cycle and seen that the drum was not spinning at correct speed. How do I fix this problem?
See if there are flashing lights on the motor. These are error codes and there should be documentation in the console that will tell you how to read them.
The first thing to do is to reset the inverter. Many times that is all that is needed.
