Fixedyet
#1 Posted : Thursday, October 6, 2011 11:49:38 PM(UTC)
Fixedyet
What would I test on the power panel to see if it's faulty? I have power to the door switch and also power to the fuse. Don't want to order an expensive part if not needed. Thanks for any input.
Jeff / APP Team
#2 Posted : Friday, October 7, 2011 7:59:58 AM(UTC)
Jeff / APP Team
Hello. The model number you provided is not working. If there is power to the fuse, you will need to unplug the wires to the fuse and test the terminals on the fuse. It should read closed for continuity. If open, you will need to replace it. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros...continuity-ohmmeter.html
Joe / APP Team
#3 Posted : Friday, October 7, 2011 8:10:26 AM(UTC)
Joe / APP Team
Fixedyet,
In most cases you program the diagnostic test mode by pressing the buttons in this sequence:
High Temp Wash, Air Dry, High Temp Wash, Air Dry
The control should run a test cycle in a matter of a few minutes.
Your Technical Data Sheet and wiring diagram should be attached to the back side of the lower kickplate, in a plastic bag, and you should be able to verify and program the test mode properly.
Fixedyet
#4 Posted : Friday, October 7, 2011 11:15:51 PM(UTC)
Fixedyet
Originally Posted by: Joe / APP Team Go to Quoted Post
Fixedyet,
Well, theres no power to the touchpad so running a diagnostic is not possible. Everything tests good so I am assuming it's the control panel(cuircuit board). I'll order one and see what happens. Thanks all. Fixedyet...
Joe / APP Team
#5 Posted : Monday, October 10, 2011 5:41:52 AM(UTC)
Joe / APP Team
Fixedyet,
Start with a control panel/keypad assembly, That component is more susceptible than the control board.
Good Luck,
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
Dishwasher stopped mid-cycle, no power (Dishwasher Repair)
by cdnfamilyguy 10/25/2021 4:37:07 AM(UTC)
Frigidaire - Ice Dispenser - No Power (Refrigerator & Freezer Repair)
by moleson 9/16/2021 1:48:52 PM(UTC)
