fredhoffmann
#1 Posted : Monday, April 27, 2009 2:53:30 PM(UTC)
fredhoffmann
Is my stove burner switch bad.
If yes, which is a replacement part # because you don't list one.
I checked the burner ohms and it was 40 to 100 I don't remember
I checked the continuity and did not get a reading
So the burner is good.
With switch in OFF position:
Ground to H1 shows 10 volts
Ground to H2 shows 120 volts
Ground to P shows 17 volts
Ground to L1 shows 240 volts
With swith in ON position:
Ground to P shows 240 volts
Since H1 and H2 go to the burner leads 120 volts won't make it work.
Please help.
